Originally Posted by thebarber
how do you disable DRL's on the echo? is it as easy as unplugging the DRL relay like the yaris?
while i like the idea of parking light DRL, it IS easier to just unplug the DRL module and turn on the lights when you need them....unless you have an RS yaris with factory fogs
Adam, i believe the DRL module works exactly the same as the one found in the Yaris. You have one wire that will activate the low beam on a pulse. Just take that and tap it to the light you want to turn on as DRL..
If you unplug the module, you will lose the handbrake light on the dash.
Sent from my ONE A2005 using Tapatalk
