Old 06-19-2016, 08:00 PM   #1
ebaut
ebaut's Avatar
Drives: Yaris 09
Measure the diameter of the smallest part of the opening (to see if the 0.62" diameter tube of the Gorilla lug nuts will enter.
Also, measure the depth from the beginning of the taper to the back side of the lug nut opening. From the picture it looks like they are really thick wheels, which would mean longer studs would need to be installed on the car.
I just measured the opening at its smallest part, i actually measured from the back, i got approximately 13mm or .52"
I think I might be screwed.
ebaut is offline   Reply With Quote
Old 06-19-2016, 08:03 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
They would not make the wheels if one could not get the wheel nuts contact they guy u got the wheels from ask what he used also take one wheel with u to a specific wheel shop not crappy tire lol
Sent from my ONE A2005 using Tapatalk
Old 06-19-2016, 08:05 PM   #3
ebaut
ebaut's Avatar
Drives: Yaris 09
I enquired to the guy i bought them from and he said it was some shop in Scarborough. Not sure where.
I also went to two "specialized" wheel shops but no luck.
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
