Old 06-19-2016, 08:20 PM   #1
ebaut
ebaut's Avatar
Drives: Yaris 09
Keeping my fingers crossed. Ill call them tomorrow. Hopefully i can post some cool pictures later on in this thread with some cool rims
Cheers
ebaut is offline   Reply With Quote
Old 06-19-2016, 08:21 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Cheers
Cool 😎
Sent from my ONE A2005 using Tapatalk
Old 06-19-2016, 09:05 PM   #3
ebaut
ebaut's Avatar
Drives: Yaris 09
Armchair detective work...
So, i measured the inside of the hole on the wheel is .62 diameter. So, if what username Texacott45 says here is true.
Originally Posted by texascolt45 View Post
I know the lugs are the same as my Tacoma,but anybody know what size and thread?sorry duh,found it.12mm X 1.5
Then based on this review.
Originally Posted by Warren
This style of lug nut was required for the installation of conical seat aluminum American Muscle GT4 (18 x 9) wheels on my 5 lug Toyota Tacoma, as the factory studs are short. These lug nuts enabled the capture of all threads for a good fit and a safe install in this application. The spline system gets you a theft protection addition with all lugs looking the same. A splined installation/removal socket is required for this application. The one I received works well and is also part of a theft protection system in this application.
http://www.brandsport.com/grla-21138et.html
And because the spline nut i used earlier is stopping right on the taper inside the hole.
Originally Posted by Exiwolfman View Post
but by using the Gorilla nuts that extra .25 extension at the bottom at .62" wide, would fit perfectly through the opening.
That makes me think those Gorillas have to be the answer or one of them.
Old 06-19-2016, 10:59 PM   #4
ebaut
ebaut's Avatar
Drives: Yaris 09
This one might be even better...
Im still calling Superior though, i want to see what they say...
Old 06-20-2016, 08:26 PM   #5
ebaut
ebaut's Avatar
Drives: Yaris 09
I called Superior in Mississauga, explained the issue. He asked me a few questions, then he said that I need Gorilla PN 21038. He was to call me back and get me a quote but he never did. Online prices in Canada for those nuts are freaking nuts, so i ended up ordering from the US a set that includes the lock nuts and hex keys for $39.99
Thanks all.
Old 06-20-2016, 08:27 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Thanks all.
Cool....crossed fingers
Old 06-20-2016, 08:32 PM   #7
ebaut
ebaut's Avatar
Drives: Yaris 09
If those dont work im setting those god damn wheels on FIRE!!!
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
