![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
we have a lot of fast and furious watchers imaging things..😂😂😂😂
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
| Echo HatchBack 15X6.5" 42ET Nitto NeoGen 205/50R15 . Rear Spacer or not ! | mpcv2000 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-10-2014 10:32 PM |
| Spacer 1NZ-FE to 1ZZ-FE | EdgarTRD1.8 | Caribbean | 2 | 03-24-2012 10:37 AM |
| Best Rear Spacer | SeriousBlack | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 08-22-2011 02:44 AM |
| Wheel/hub spacer, PLS help | evo165 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 08-18-2009 02:21 AM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
