Old 06-26-2016, 02:12 AM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Sounds like a scam honestly. Kind of like the engine grounding kits.
Sent from m-o-b-i-l-e
Old 06-26-2016, 02:16 AM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
actually for E coded yaris..but i already got C coded(RS Vitz) from japan so yeah whatever..but quality made product though 😂😂😂😂😂
they from big shop called AZC, i dont think its a scam
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 07-23-2016, 08:18 PM   #3
SirDigby
Drives: 2007 yaris 3 door
if you properly ground your vehicle and lower your voltage drop, it will vastly improve the life of all electrical components and engine battery. I am a firm believer in grounding kits, and BG products. (another thing people claim is a scam)
a grounding kit costs less than $20 to make and only weighs like 2 lbs. my last vehicle I bought brand new. I built a ground system for it right away. in the 13 years and 338,xxx miles I never replaced a single bulb for burning out, and I purchased 1 battery. grounding electronics is good stuff....
Yaris '99 MAF sensor location. MrNinety DIY / Maintenance / Service 0 11-04-2014 10:12 AM
Recommendations on Mass Air Flow Sensor (MAF) dyslexicanaboko Performance Modifications 11 02-08-2011 10:24 PM
Help me pic my best pic... Sabretooth Photo-Video-Media Gallery 17 06-14-2009 07:52 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
A pic thread showing aftermarket springs/suspension? Pitt Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 03-30-2009 12:17 PM
