Old 07-04-2016, 07:40 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
Your pistons etc will be fine. Depending on how it broke you may need to replace the oil seal as well, but probably not. Typically what happens is the rubber part tears, allowing the pulley to come apart. The middle part of the pulley is probably still correctly attached to the crank, so the crank should be fine. You're probably fine to just replace the pulley, belt etc. I wouldn't bother running it with the pulley off as it will make a mess and it's unlikely to have engine damage.
Cheers.
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 06:57 AM
Crank shaft pulley bolt removal? TonyUK DIY / Maintenance / Service 10 02-09-2014 01:24 PM
DIY: MI Lightweight Pulley jpmck03 DIY / Maintenance / Service 36 12-09-2013 05:32 PM
Installing MI Crank Pulley? oliveskate DIY / Maintenance / Service 6 09-25-2013 12:19 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
