Old 07-23-2016, 03:15 PM   #1
Did you check the big 120A fuse inline with the positive battery terminal. There are 2 fuses there, one 120A and one 60A.
If you foolishly didn't disconnect the battery before replacing the alt, you could have very well blown one of the 'Main' fuses.
Old 07-23-2016, 04:02 PM   #2
GoodAsGoldYaris
Drives: 2007 Yaris
You're right, 120A is fried and I'm a fool trying to save a buck, learning the hard way.
Can you replace just the fuse or do you have to do the entire fuse block that includes the 60A?
GoodAsGoldYaris is offline   Reply With Quote
Old 07-23-2016, 04:06 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
the fuse block comes as one so you get both 120/60 and price is 24$ plus tax at toyota .
Old 07-23-2016, 04:04 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
+1
definitely the 120 is blown from the problem described...and its 24$ bucks from Toyota , location is on top of the positive terminal .
WTH, man? Broken off antennas Kar98 Third Gen Yaris General Discussion 2 05-15-2015 06:04 AM
Broken broken aircon pump pulley + dual mass crank pulley Bluecatcottage DIY / Maintenance / Service 1 03-31-2013 07:55 AM
How to replace a broken wheel stud Rami yaris DIY / Maintenance / Service 4 06-28-2012 05:34 PM
Altenator Belt Broken After Replaced by Toyota Yaris_guy DIY / Maintenance / Service 12 01-18-2011 09:14 PM
Broken 40/60 Back / Rear Split Seat Handle / Lever alex_melodymaker DIY / Maintenance / Service 9 10-31-2009 04:55 AM
