Old 07-24-2016, 01:07 PM   #1
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
Originally Posted by TRD SPEC View Post
Honestly adding a throttle body spacer isn't going to do much cause all it does is increase the length between throttle body and the intake but still by doing that you will increase about 0.5 amount of torque at low rpm i believe,i change my throttle body to 1zz-fe and custom made a spacer cause my intake manifold is 3 hole and the 1zz-fe is 4 hole,than custom made a short ram intake my self[some clamps and a samco hose lol],i can feel the torque came in early but doesn't effect much in high rpm...if my butt dyno is correct i say increase 60% in low rpm 30%in mid and 10%in high....but still the 1zz-fe throttle body is 60mm and stock 1nz fe is around 46mm by porting it i think you can get to 47mm maybe?wouldn't change much.
But what crank pulley you use?and how much cc does the 1jz have?can i use that injector with only ron95 fuel?
isn't your TB drive by cable since you said it was 3 holes while the 1ZZ TB is 4 holes drive by wire
Fluxtasy is offline   Reply With Quote
Old 07-24-2016, 10:29 PM   #2
TRD SPEC
TRD SPEC's Avatar
Drives: Ncp42
Yes,my car is ncp42
Sent from my 3006 using Tapatalk
TRD SPEC is offline   Reply With Quote
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 08:01 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
