Old 07-25-2016, 02:31 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
Originally Posted by TRD SPEC View Post
Can't wait to see the dyno and more info about it.
Sent from my 3006 using Tapatalk
change of plan.. bolt on racing cam...about the same price...rather go cams than piston
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 07-25-2016, 02:33 AM   #2
TRD SPEC
TRD SPEC's Avatar
Drives: Ncp42
Wut...... awwwww
but still with higher lift cam doesn't that make it more power to the mid and high range and less on the low?if you doesn't upgrade the compression i don't think the car would accelerate well unless you hit top speed alot...
TRD SPEC is offline   Reply With Quote
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. Idjiit Off-topic / Other Cars / Everything else Discussions 6 10-06-2017 05:10 PM
test drove a fit...mirage...and a yaris 428CobraJet Third Gen Yaris General Discussion 15 05-17-2015 02:08 PM
On tire pressures, the Yaris, and the Prius sbergman27 Fuel Economy Forum 18 04-05-2010 05:35 PM
