![]() Drives: 2007 Yaris Join Date: Aug 2016
My borrowed 2007 Coupe has similar issue. Th screw on right side of striker was just sitting there loos and not torqued to anything. I just lifted it out. The left side screw is Taught but will not adequately hold the striker in alignment.
This Yaris I have has rectangular opening under the striker plate. The opening is too large to accommodate an over sized washer. I am thinking...Maybe...Cut a rectangle piece of plate maybe about .06 + Thick. I can slide the plate into the rectangle hole and turn the plate 90 degrees to allow contact with chassis frame. First I will Drill hole in it to accommodate screw when I self-tap it into the piece of plate. Thinking to insert small screw for manipulation of plate to correct location. Probably have to glue the plate to the frame for temporary hold so I can place the striker over it and insert screw. I came into this forum hoping someone had a remedy for this issue but appears not...Yet. |
#2 | |
Somethings I found so far. This is not my problem but maybe somone else: http://parts.villagetoyota.com/showA...rimLevel=13993 |
| My car doesn't start | yaristhebest | General Yaris / Vitz Discussion | 11 | 01-10-2013 10:02 PM |
| Car start problem | jorizk | DIY / Maintenance / Service | 14 | 04-26-2010 06:36 PM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
