Old 08-16-2016, 10:43 AM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Yeah, I think that was Jason Armstrong, when his swapped sedan was on One Take. I understand it for that type of application, but was having a hard time understanding the benefit when doing straight line acceleration.
Old 08-16-2016, 01:28 PM   #2
rabbito
rabbito's Avatar
yeah jason armstrong video 😁 i be doing samething when i hit curvy roads here..
benefit of straight in line...hmmm...i race my friends yaris with manual on straight line...of course his has 5 speed...mine has like long gears with D as over drive after 120km....but mine has more mods so its much faster...i had this issue where rpm took forever to go up...light weight pulley helped a little bit...straight line benefit? none 😧😧😧 but in traffic comfortable af 😆😆😆
my other 2 cars have shifters on steering wheel with 6 speed which makes more sense..i understand your point though...😥😥😥
Cosmetic: Toyota red emblem
How to check automatic gear transmission oil iaq DIY / Maintenance / Service 4 12-04-2008 01:50 PM
Will thicker automatic transmission oil help with pick-up ? nurburgring General Yaris / Vitz Discussion 3 08-01-2007 04:15 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Is that bad for automatic transmission? hans_fh General Yaris / Vitz Discussion 9 11-20-2006 07:25 AM
