The seized pin/hole has lost metal dues to rust. So either the pin is too small, or the bracket hole too large. You will have to replace either or both to get it correct. It's also possible the pads are too small as well and moving up and down in the brackets. Just take a small screwdriver and try prying them up and down. If the movement is excessive, replace the pads.
For the pins you could try using the top pin on the bottom hole, or just getting new pins but it is probably the bracket that is worse. Cheers. |
| Passenger side rear wheel noise | theb | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 09-14-2015 09:29 PM |
| Water leaking into front passenger side from air vent | flukeboy | General Yaris / Vitz Discussion | 2 | 12-07-2013 10:02 AM |
| Passenger Side Frame rail | Yaris_80 | DIY / Maintenance / Service | 4 | 03-31-2013 10:30 AM |
| Passenger side windshield wiper | daf62757 | General Yaris / Vitz Discussion | 1 | 12-23-2011 05:12 PM |
| Noise on the passenger side with audio | zachryboles | DIY / Maintenance / Service | 1 | 10-19-2011 08:32 PM |
