Old 08-18-2016, 12:17 AM   #1
alias06
Drives: 2008 Red Toyota Yaris
So you are modded and it took you 15 seconds to reach 60mph?? Or is that actually 100 mph?
alias06 is offline   Reply With Quote
Old 08-18-2016, 12:22 AM   #2
rabbito
rabbito's Avatar
😂😂😂😂 what would you expact from yaris..even my camrys faster than yaris lol
Cosmetic: Toyota red emblem
How to check automatic gear transmission oil iaq DIY / Maintenance / Service 4 12-04-2008 01:50 PM
Will thicker automatic transmission oil help with pick-up ? nurburgring General Yaris / Vitz Discussion 3 08-01-2007 04:15 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Is that bad for automatic transmission? hans_fh General Yaris / Vitz Discussion 9 11-20-2006 07:25 AM
