Old 08-18-2016, 12:34 AM   #1
alias06
Drives: 2008 Red Toyota Yaris
No one is upset here (at least I'm not). Just making an observation that it took you 15 seconds to reach 60mph in a modded Yaris while listed stock is faster than the video that you have posted. I might be tempted to go out now and record a video of how slow my car is...
alias06 is offline   Reply With Quote
Old 08-18-2016, 12:35 AM   #2
rabbito
rabbito's Avatar
show how its done 😉😉😉
Cosmetic: Toyota red emblem
How to check automatic gear transmission oil iaq DIY / Maintenance / Service 4 12-04-2008 01:50 PM
Will thicker automatic transmission oil help with pick-up ? nurburgring General Yaris / Vitz Discussion 3 08-01-2007 04:15 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Is that bad for automatic transmission? hans_fh General Yaris / Vitz Discussion 9 11-20-2006 07:25 AM
