![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
Showing us how to shift on an automatic transmission like it is unknown to the whole world is just a silly idea, fast and furious has been doing it in the early 2000s. His video shows him controlling the gears by shifting at higher rpms which is what shifting on the auto trans does gear by gear. I admit that I didn't account for him taking off his feet on the "hill" but nevertheless his other post about being jealous of a piston swapped yaris doing 8-9 second 0-60s and with his modded yaris not being able to replicate it leaves room for criticism.
#2 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
| How to check automatic gear transmission oil | iaq | DIY / Maintenance / Service | 4 | 12-04-2008 01:50 PM |
| Will thicker automatic transmission oil help with pick-up ? | nurburgring | General Yaris / Vitz Discussion | 3 | 08-01-2007 04:15 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| Is that bad for automatic transmission? | hans_fh | General Yaris / Vitz Discussion | 9 | 11-20-2006 07:25 AM |
