yea. the rubber is stretched into a groove. be gentle. grease them pins good!
as to the rotors; if you have a second car, you can take them you get measured/machined at a NAPA or some other parts stores as well as machine shops. the parts stores will have the measurements on their computers, the machine shop will be able to measure with the specs you pull of the internet. (idk what they are) you can return the rotors to where you bought them if you don't use them. if you keep them, store them upright, like books, to keep them from warping. (most everyone stores them improperly, even parts stores. it's a good idea to get NEW rotors machined in some cases) |
#2 | |
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
As for the little rubber boots on the bolts... So yall are saying to just sort of gently pry them off the bolt? And that they will sort of just pop out of a grove, on their own? The boot doesn't need to be twisted in any way? |
bump
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| Time to replace rotors. Which brake upgrades? | BennyLava | DIY / Maintenance / Service | 25 | 05-16-2016 05:57 PM |
| Question about brake booster replacement | RutherfordmanX | DIY / Maintenance / Service | 1 | 01-08-2016 11:34 PM |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| Wheel Bearing Replacement (FRONT) | justjesus | DIY / Maintenance / Service | 11 | 04-26-2014 07:38 PM |
