Old 08-27-2016, 07:26 PM   #12
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by tmontague View Post
Use rubber safe grease only and don't over apply it. I use rubbing alcohol to remove the old grease from the slider pins and it worked well.
I use sil-glide. it's a good non-drip, waterproof high temp grease. it's also good for many other moving parts too like door jams and sunroofs. and it's clear colored.
NAPA $6
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Time to replace rotors. Which brake upgrades? BennyLava DIY / Maintenance / Service 25 05-16-2016 05:57 PM
Question about brake booster replacement RutherfordmanX DIY / Maintenance / Service 1 01-08-2016 11:34 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
