Old 09-06-2016, 06:58 PM   #1
Yaris_Mac
Drives: Gas saver
Hi,
Can I use the stock 2008 Yaris 5 speed manual transmission with the 2ZR-FE?
My car is stock except for:
Fidanza Flywheel (8.64 lbs)
NST crank pulley
McLeod Stage 1 clutch
K&N OE filter box...
...That I installed this weekend.
Yaris_Mac is offline   Reply With Quote
Old 04-06-2017, 11:44 PM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Originally Posted by Yaris_Mac View Post
Hi,
NST crank pulley
Yes you can.
Old 04-07-2017, 09:56 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yes, you can use the gearbox but you need the xD mounts (all six pieces) and the xD shift cables. The flywheel won't work (6-bolt on the Yaris vs 8-bolt on the xD) but the pressure plate and friction disc should be fine.
The 2zr-fe engine swap guide ArmstrongRacing Performance Modifications 416 08-14-2023 03:14 PM
engine swap yaris9876 DIY / Maintenance / Service 12 12-26-2013 10:27 PM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 06:20 PM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 01:40 PM
