Old 09-07-2016, 12:37 PM   #1
sim085
Drives: Vitz 2007
The car has 85,942 Km.
How can I find if it has a leak?
Is there any other indication to know if the problem is with the engine?
Originally Posted by NYC-SE View Post
You either have a leak, which shouldn't be too hard to find, or you are burning that oil, which would indicate engine problems, most likely valve guides or piston rings. How many miles on the engine?
sim085 is offline   Reply With Quote
Old 09-07-2016, 01:49 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
At that mileage I wouldn't think engine problems but it's still possible. Is the car performing right otherwise?
As for a leak do you see any oil an the ground after leaving the car parked overnight? Best to just get a flashlight and inspect the engine from top and bottom. You should be able to see evidence of a leak if one is present.
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Really Bad Engine Sludge... monchito18 DIY / Maintenance / Service 27 05-14-2014 11:47 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 01:46 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
