Old 09-13-2016, 05:54 PM   #1
spookybathtub
Drives: 2007 Yaris HB
This is annoying for me too. My shoes are size 12, and I did the "big foot mod" already, which helps. But still, it's hard to press the clutch pedal all the way down when I'm wearing shoes with rigid soles. About 10% if the time, it grinds as I try to shift with the clutch partially engaged. To avoid this problem, I usually drive barefoot.
spookybathtub is offline   Reply With Quote
Old 09-13-2016, 11:12 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
You need to adjust the pushrod connected to the pedal. Loosen the lock nut and then pull the pin out and give it a couple turns out. Just make sure you still have freeplay when the pedal is all the way up or you'll burn out the through out bearing.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
clutch adjustment 1krzys DIY / Maintenance / Service 0 09-01-2011 03:10 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
