Old 09-13-2016, 11:09 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by jamez View Post
I think you are right, Scott. I took a closer look where the hoses connect on the other side of the firewall and found a little bit of coolant pooled around the rubber grommet at the firewall. I put a second hose clamp on each of the hoses connected to the core and haven't noticed any more leaks. So I guess I got lucky this time!
Thanks very much for the help!
If that's the case, replace the hoses and clean the connections off. They're probably breaking down and failing.
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Yaris 2009 vs 2012 steinway General Yaris / Vitz Discussion 5 09-27-2012 05:21 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
