Old 09-14-2016, 04:22 AM   #1
Garth g.
Drives: 07 Yaris 2dr hatchback
Thanks for the guidance. I didn't change the cv half shaft assembly's yet, did the sway bar links though. I soaked the nuts and bolts a couple of days with w-d40 and liquid wrench 🔧. I also cracked them first with a breaker bar, then used a gear wrench and a 6mm Allan key. I almost stripped the last nut, good thing I didn't I wasn't prepared. I torqued them to 59ftlbs,not sure if that's accurate (found a chart on my phone) I think the grease that's on the cv boot is coming from somewhere else like I said it's there sometimes and there is no clicking or damage. Had to start this job at 11pm work crappie hours. I feel enthused.
Garth g. is offline   Reply With Quote
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Bumper replacement mchamp00 DIY / Maintenance / Service 0 07-03-2015 10:45 PM
Rear Speaker Replacement 2DR Hatch salty3142 In Car Entertainment + Electronics (audio / video / alarm) 1 06-06-2015 12:38 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
