Old 09-15-2016, 03:41 PM   #1
dogsridewith
Drives: 2007 2-door hatchback
oxygen sensor air-fuel ratio analog multimeter
Any difference between an "Oxygen Sensor" and this "AFR sensor"? Does it output an analog voltage that can be read with a multimeter?
I ran a multimeter on my carbed 89 Tercel's O2 sensor (only one, in down pipe just below exhaust manifold) and it read so close to spec (.75 volt?) that I wasn't sure of the whole control circuit's function...was something driving that reading to .75 besides oxygen in the exhaust gas?
Old 09-15-2016, 04:39 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Yes an O2 sensor reads 0.0v - 1.0v.
0.0 is lean and 1.0 is rich. I'm not 100% on what afr that translates to but .5v should be an afr of 14.7. It's reading on a car that uses one will bounce up and down because the sensor has a slower response and the ecu with use an average reading to calculate the fuel delivery.
An AFR sensor reads from 5.0v - 0.0, and is opposite to an O2 sensor. It will read much more accurately and has a much wider range and is much faster.
The two sensors are NOT interchangeable.
2009 Yaris sedan problems BennyLava DIY / Maintenance / Service 5 12-26-2020 05:14 PM
Yaris 2 D4D 2009 without AC serpentine belt rasyaya DIY / Maintenance / Service 6 07-17-2014 09:02 AM
2009 Yaris and wind sailing GrayYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 10-26-2013 07:52 PM
Just bought: 2009 Yaris Sedan Prometheus Bound New YARIS Purchase Forum 2 05-11-2013 11:45 PM
