Old 09-16-2016, 08:44 PM   #1
Originally Posted by AtheistExtraordinaire View Post
Did you ever figure out or solve this problem? I am having the EXACT. SAME. PROBLEM. Same year, same model...
I have ordered a new blower motor but don't know if I should have, or if I need to order the relay or resistor?
If it cuts out on high still, then the blower is the issue. If it only cuts out on lower speeds, then the resistor or switch is more likely the issue.
