Could be a number of things. Start with the above. Add in cleaning the terminals on your battery. Take a meter to the battery and check to see if you are indeed getting the full 12v's out of it. Cells do go bad in batteries over time, especially if you've let the battery run dead a few times and had to jump start the car. Many many many different things to check here so start with the obvious things first and anything that sucks air.
| yaris hard starting when hot, fine when cold | ianpog | DIY / Maintenance / Service | 11 | 08-12-2015 09:24 PM |
| problem with co-worker yaris, need opinion on what it could be. | Adriaan | DIY / Maintenance / Service | 5 | 10-20-2014 06:39 AM |
| 2009 Yaris starting issue -need help | cudchew | DIY / Maintenance / Service | 15 | 12-16-2011 02:24 AM |
| Warrany Service Problem? | 2009Yaris | General Yaris / Vitz Discussion | 4 | 03-31-2011 04:56 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
