#1 | ||||
![]() Drives: 2008 Toyota Yaris 4D Sedan Join Date: Apr 2011
The two speakers in the lower doors by our legs produce no sound at all. Same for the small round one by the window on the left. Small round one on the window frame on the right does crackle and kicks sometimes if I crank the volume way up but then cuts out again if lower the volume. Two back speakers seem to be fine apart from a volume difference. (left is lower than the right, need to adjust the balance to L-3 for it to sound even) Quote:
Here's my current Amazon shopping list (not including speakers). Am I missing anything? Pioneer AVH-X2800BS Scosche Radio Wiring Harness for 87+ Ta Pwr/4Spk with Butt Connectors Metra 95-8202 Toyota DDIN Multi Dash Kit MicroBypass ALL AVH-X Video In Motion Interface for Select Pioneer Receivers Rerii 3ft 1 Meter USB and 2RCA to USB & 3.5mm Female Flush Mount |
#2 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
The ones by the legs and the doors are one and the same, they are the front speakers. The ones by the legs (front) are the mids - they produce the vocals - and the ones up top (small ones) are tweeters - they produce the cymbals, etc. They are both connected to the front outputs of the stereo, if you trace it the tweeter usually have "something"in the wiring (its a capacitor) before it reaches the headunit. Sometimes both of them go into a different "something" (called a crossover, and its like a small box) and this something is the one connected to the stereo. Ive tried to simplify the words for you :) Which then reminds me, are those front speakers stock from factory? If not, my money goes to wiring issues. Sent from my G9208SS using Tapatalk |
#3 | ||
Neither the mids or tweeter on the left are working at all. Mids on the right work and the right tweeter kicks in if I turn the volume way up but cuts back out once I lower the volume, and there is crackling when that happens. Quote:
I notice that lots of 6.5" speakers are all in one. So to replace the front speakers I want a pair that has separate tweeters, and if I want to replace the rears I should be looking at speakers that are all in one? Speakers are all stock. |
#4 | |
In any case, youre correct. For fronts you need to find component speakers (separate tweeters from woofer/mid) while you need to find coaxials for the rear. However with a good set of front components, you dont really need to replace the factory rears. ;) Sent from my G9208SS using Tapatalk |
#5 | |
I"ve actually heard a lot of SQ installs are now focusing exclusively on front speakers and not even bothering with sound from the back at all. Will look into the wiring testing mentioned earlier too now. As for the rest of the shopping list above? I never heard back from anyone. Does that sound about right? Am I missing anything there? |
#6 | |
Other than that, your shopping list seems about right for the first 3 items, as im not sure about the5th one Rerii. Our pioneers av receivers come with the USB extension cable and steering wheel adapter (3 open ended wires to a 2.5 or a 3.5mm jack). Sent from my G9208SS using Tapatalk |
| 2012 Audio Upgrade FAQ and Build Log | muffin_top | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 01-19-2022 06:28 PM |
| how do I connect an amp to a standard head unit? | marshall_8up | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 09-22-2021 05:44 AM |
| Pioneer AVIC F900BT Head Unit + Pioneer Speakers. | thorntonas | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 03-06-2010 10:02 PM |
| Fitting amplifier to Yaris head unit | nish1979 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 04-08-2009 06:18 AM |
| Does the non integrated head unit do any processing? | ponieswhee | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 05-07-2007 09:00 PM |
