Old 10-22-2016, 12:32 PM   #1
SirDigby
Drives: 2007 yaris 3 door
no, a flat tire on the (us) passenger rear would not cause excess turn radius to the right. you would need to be pulling more than 3g's to cause turning to break the bead on the tire to cause leakage, unless there is bead damage from mounting the tire improperly. sounds like there is damage to rear axle or to passenger front control arm. but damage like this doesn't just happen from wear...
