![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
No antiseize with NGK
If you use NGK plugs, do not use anti-seize. You could over torque them and break the treads. Very bad. NGK plugs are plated to NOT need anti-seize.
https://www.ngksparkplugs.com/about-...ut-spark-plugs |
#2 | |
Do you know if a 2005 Camry has these plugs? Unfortunately I waited until 100k to take them out and now they are seized. I'm too scared to force them out if they strip that will be that. Carbon from combustion builds up on the threads, seizing them. That's different from moisture or corrosion. It's well known that if you use a torque wrench on lubed threads they ll be overtorqued. Don't use one and everything will be fine.
huh. I always use antiseize on ngk (or any) plugs. it's only bad if you over applicate. (very thin swipe/layer, then roll around sister plug threads to pull even thinner. keep electrode and ground clean) if you install them to "finger tight" then an 1/8-1/4 turn you feel the crush washer crush. I have never had any issues. installed hundreds of plugs over the last 20 years....
| Buying a yaris with 106k miles. need some insight | Drummer829 | New YARIS Purchase Forum | 15 | 03-12-2013 07:16 PM |
| Possibly purchasing a Yaris, how many miles do you go without major repairs? | chriswf | New YARIS Purchase Forum | 31 | 09-15-2012 01:14 PM |
| Is extended warranty (6 yrs/75,000 miles) worth it for 2009 Yaris sedan? | Marls | General Yaris / Vitz Discussion | 5 | 05-29-2011 11:23 PM |
