Old 11-03-2016, 10:58 PM   #1
SirDigby
Drives: 2007 yaris 3 door
why? I don't understand why you'd want less MPG without performance gain. i'm confused...
Old 11-04-2016, 12:15 AM   #2
rabbito
rabbito's Avatar
less mpg without performance gain...how -_-; im running an ecu...
Sent from my SM-J710F using Tapatalk
Cosmetic: Toyota red emblem
Old 11-06-2016, 11:28 PM   #3
alias06
Drives: 2008 Red Toyota Yaris
This is one of those "mods" you do because:
a. You plan to make big power and need the better cooling/higher octane rating that E85 provides over the typical pump gas.
b. You want to do it for bragging rights, and nothing else. Who cares if you get less mpg, its E85 converted JDM status Yo!!!
alias06 is offline   Reply With Quote
Do any Yaris owners use premium gas ? DanMC Third Gen Yaris General Discussion 38 11-06-2013 10:36 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
