Old 11-05-2016, 09:21 PM   #1
Frank the Tank
Drives: 2007 Toyota Yaris
enough about gas prices.
what performance gains did you get from this mod.
Frank the Tank is offline   Reply With Quote
Old 11-05-2016, 10:09 PM   #2
rabbito
rabbito's Avatar
im currently on advance timing ecu..only about 10hp gain with current E85 set up..my ecu is the cheapest with basic software outline for advance timing..i did a write up in the past..can check them out
planing to add fuel injection ecu soon..yes, i can use 2 seperate ecu...no, i did not purchase the complete piggy back due to financial issue 😅😅😅
Sent from my SM-J710F using Tapatalk
Cosmetic: Toyota red emblem
Do any Yaris owners use premium gas ? DanMC Third Gen Yaris General Discussion 38 11-06-2013 10:36 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
