Old 11-07-2016, 09:24 AM   #1
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Refinishing headlight lense vs buying new/near new headlights?
I'm at 265k miles and my headlights have taken a beating on my 2009 hatch... Atlanta construction means I might as well be driving on a gravel road!?!
I'm in the process of revamping the front end of the car and adding Xpel after the paint work. A shop owner told me they could sand down the lenses and then clear coat them for like $120 and they'd look like new. Is that worth my while or should I hold out for some ones that don't look like someone spent 7 years throwing rocks at them???
firebird1999us is offline   Reply With Quote
Old 11-07-2016, 11:06 AM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I didn't have a ton of pits in mine, but they did cloud over a bit. I had them polished and clear coated by my body shop while they were doing some paint work for me and was super pleased with the results. This was a while back and they've held up.
On Instagram
On Wheelwell
Old 11-07-2016, 11:14 AM   #3
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I've had my headlamps polished and the result looks great. The plastic material is still slightly more yellow than original, but perfect otherwise. If your roads are that bad, I would recommend not wasting money on new lenses.
Sent from my LG G2 with CM13 using Tapatalk
tarkus is offline   Reply With Quote
Old 11-07-2016, 11:19 AM   #4
firebird1999us
Drives: 2003 Mach 1
I'm adding Xpel covering over them which will help against a lot of the smaller stuff... granted nothings going to fix a bolt flying at the car. But it should greatly improve chances of surviving without getting busted.
Old 11-07-2016, 12:18 PM   #5
tmontague
tmontague's Avatar
I've sanded, polished and then clear coated my headlights on both my card and have had no yellowing or clouding come back. If you do it properly it will work for a decade. The key is to re coat with a non yellowing uv resistant clear coat with multiple coats applied. The sanding strips off the faxtory coat which is why the yellowing and clouding happens.
Like you said, not much will protect against rocks and bolts though.
Old 11-07-2016, 01:31 PM   #6
tarkus
tarkus's Avatar
With the lenses newly polished by a professional body shop, I found a very subtle yellowness compared to a brand new lens. But this is really subtle and wouldn't be noticed without placing a brand new one right beside. Overall, I highly recommend repolishing.
Old 11-07-2016, 03:47 PM   #7
tmontague
tmontague's Avatar
I haven't compared my results to brand new lenses but I sand them with various grits for about 3 hours and the whole process takes me about 5 hours. I suppose a professional could also use power tools to speed it up but generally time is of the essence with them so it could be possible that they didn't take enough off. Or it may not be possible to get them the same as brand new lenses.
Old 11-07-2016, 11:57 PM   #8
tarkus
tarkus's Avatar
I believe that to be the case, as it looks like the clear plastic has slightly altered in color over time all the way through - its a 2006. Keep in mind that the lens is subjected to a lot of heat from the halogen bulbs, from the inside. But you wouldn't know without directly comparing to a brand new lense.
The body shop who did the job are family friends of mine, and their standard of work is phenomenally good.
Old 12-13-2016, 12:18 AM   #9
othater
Drives: 07SedanS06Taco
Clear coat
Hi, What brand clear coat with UV protection did you use?
othater is offline   Reply With Quote
Old 02-23-2017, 02:03 AM   #10
miiser
miiser's Avatar
Drives: yaris 2009
It's American accents
miiser is offline   Reply With Quote
Old 11-07-2016, 01:48 PM   #11
dogsridewith
Drives: 2007 2-door hatchback
what does Toyota dealership parts want for brand new 07-09 shells? any aftermarket? brands?
Old 11-07-2016, 04:54 PM   #12
M4One
Drives: 2007 Toyota Yaris Hatchback
I don't know how bad they are, but if you have the time, you could just do it yourself. Much cheaper. https://www.youtube.com/watch?v=UEJbKLZ7RmM
M4One is offline   Reply With Quote
Old 11-07-2016, 05:54 PM   #13
tmontague
tmontague's Avatar
^that's the process I did, just make sure you spray the water on the headlight when its cloudy after sanding to see how they will look when finished. This makes it easier to see any areas you missed and to show you how it will look when polished and clear coated
Old 11-07-2016, 08:08 PM   #14
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
2000 grid sandpaper
Wet sand in back and forth direction no circle motion till all is removed use plenty of water, water spray btle works best
Dry it off after use wax and best to use waxing buffer if possible or elbow grease, wipe clean and repeat with wax sealer.
Your light will look new and it takes about 30 min total.
Sent from my SM-G925F using Tapatalk
Old 11-08-2016, 11:12 AM   #15
firebird1999us
Drives: 2003 Mach 1
Originally Posted by Exiwolfman View Post
2000 grid sandpaper
I don't think I can use a wax/sealer underneath the Xpel stuff. I'm under the impression it needs to be a bare (painted) surface.
I could sand it down myself and reclear it... anyone have any suggestions on paint that will work? Although the cars already going to be in the shop for paint work so I'm inclined just to have them do it and avoid the hassle. I've got a newborn so time comes at a real premium at the moment....
Old 11-07-2016, 11:10 PM   #16
SirDigby
Drives: 2007 yaris 3 door
yeah. do it yourself for $20. you'll feel awesome that you made your car look new and you saved $100.
Old 12-13-2016, 04:53 AM   #17
tmontague
tmontague's Avatar
I can't remember the brand, I just went to my local Canadian tire and grabbed a semi gloss or gloss clear coat that was if resistant and non yellowing as per the can. They only jade on brand that matches these requirements.
Old 02-23-2017, 02:03 AM   #18
miiser
miiser's Avatar
Drives: yaris 2009
American accents.
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
WTS: 2008 OEM Headlights, headlight harness, misc parts wildcard Items for Sale by private party 1 05-17-2016 08:50 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
