Old 11-07-2016, 01:31 PM   #1
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Originally Posted by tmontague View Post
I've sanded, polished and then clear coated my headlights on both my card and have had no yellowing or clouding come back. If you do it properly it will work for a decade. The key is to re coat with a non yellowing uv resistant clear coat with multiple coats applied. The sanding strips off the faxtory coat which is why the yellowing and clouding happens.
With the lenses newly polished by a professional body shop, I found a very subtle yellowness compared to a brand new lens. But this is really subtle and wouldn't be noticed without placing a brand new one right beside. Overall, I highly recommend repolishing.
Sent from my LG G2 with CM13 using Tapatalk
tarkus is offline   Reply With Quote
Old 11-07-2016, 03:47 PM   #2
tmontague
tmontague's Avatar
I haven't compared my results to brand new lenses but I sand them with various grits for about 3 hours and the whole process takes me about 5 hours. I suppose a professional could also use power tools to speed it up but generally time is of the essence with them so it could be possible that they didn't take enough off. Or it may not be possible to get them the same as brand new lenses.
Old 11-07-2016, 11:57 PM   #3
tarkus
tarkus's Avatar
I believe that to be the case, as it looks like the clear plastic has slightly altered in color over time all the way through - its a 2006. Keep in mind that the lens is subjected to a lot of heat from the halogen bulbs, from the inside. But you wouldn't know without directly comparing to a brand new lense.
The body shop who did the job are family friends of mine, and their standard of work is phenomenally good.
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
WTS: 2008 OEM Headlights, headlight harness, misc parts wildcard Items for Sale by private party 1 05-17-2016 08:50 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
