Commander
Hello, this is one of my first posts, so I'll try to make it work.
My 2007 Yaris S Sedan has Manual door locks and windows. I was replacing the speakers when I messed up on my passenger door. I opened the door, took off the plastic panel, replaced the speaker, somehow dislocated the door lock and handle clips to the metal bars that work the doors hinge. I replaced the panel without knowing the door locks and handles were not attached, screwed it all nice and together, and closed the door. Now I can't open the door by the outside lock, the inside handle, the outside handle, and the only way to fix it is to remove the panel, which cannot now be accessed due to the door not being able to be opened. I have tried removing some plastic covers (i.e. the plastic handle cup comes off) and this allows me to see some possible access points, but nothing has show promise yet. So, I was thinking: would a slim jim type of door opener grab the metal cable and be able to open the door? Is there some way that you know of that works? Or am I fucked? Thanks! |
I know that door hinges are accessible if you remove the fender panel.
Sent from my SM-G930W8 using Tapatalk |
Commander
So you're saying if I remove the plastic wheel-well and then the metal fender that's above the wheel? I'm not against the idea, just want to clarify.
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Try to find the door cables using the small opening you have. Thats your best bet. Small hands would probably be best.
Still havent figured out how you can possibly mess the connections to the outside door handle. Sent from my G9208SS using Tapatalk |
Commander
Thanks. I'll try sometime soon when I get my slim-jim in the mail. Then I'll try the openings I have, cuz I can just almost get to them, then the fender as a last resort.
| Tags |
| 2007, door, lock, sedan, yaris |
| Permanently remove passenger seat? | tendomentis | DIY / Maintenance / Service | 12 | 12-01-2017 02:16 PM |
| Passenger Power Window replacement | AMOKS | DIY / Maintenance / Service | 0 | 03-15-2016 09:29 PM |
| Passenger Airbag Question | RedStickHam | DIY / Maintenance / Service | 13 | 06-23-2013 04:39 PM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| Anyone know how the passenger seat detection system works? | rage2 | DIY / Maintenance / Service | 5 | 05-12-2007 07:22 PM |
