![]() Drives: '09 Yaris Join Date: Mar 2011
Can I use a head unit from newer Toyota Hilux etc
I have a 2009 Yaris with a double din stock radio. No bluetooth, no reversing camera. But it has the steering wheel controls.
If I buy a stock head unit from a newer Toyota with Bluetooth and AV in for reversing camera etc, will it work? Will the steering wheel controls work? I'm ok with building a simple harness if required. Does it have to be a Yaris, or would a double din from a hilux, camry, etc have the same interface to the steering wheel controls? There are people selling the stock units cheap when they upgrade theirs, I don't need better sound I just want bluetooth and maybe a reversing cam connector, plus the steering wheel controls to still work. My wife likes the streamline of a stock radio so I'm happy to upgrade that way. |
#2 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Sent from my G9208SS using Tapatalk |
![]() ![]() Drives: 2013 Hatchback Join Date: Dec 2012
Toyota uses the same connectors across almost all the models (except with ampified JBL audio.) so I think a OEM hilux Toyota 200mm size unit will fit nice.
Now the funtions you are interested (BT and reverse camera) maybe no were planned for your car, and some wiring will be missing from the main harness (like de reverse wire in my car). If the steering connectors are the same, probably is just plug & play and there is no need for a SW interface, for the reverse camera if you use a non oem model it will need a something like the MetraAX-TOYCAM adapter to add one to the new oem headunit for video and power supply. like jcboy says: Better look at the back of the unit and compare to the connectors in your car. |
#4 | |
Drives: Toyota camry Join Date: Nov 2016
| Add USB audio to factory head unit | Gladmo2 | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 01-02-2013 11:25 PM |
| Feeler: Pioneer AVH-6850DVD 2-DIN head unit + extras | eTiMaGo | Items for Sale by private party | 19 | 08-07-2009 09:49 AM |
| installed head unit... | punch | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 06-29-2006 12:06 AM |
