Old 11-18-2016, 08:59 AM   #1
MatthewSanders
Drives: Toyota camry
Originally Posted by joell View Post
Toyota uses the same connectors across almost all the models (except with ampified JBL audio.) so I think a OEM hilux Toyota 200mm size unit will fit nice.
Now the funtions you are interested (BT and reverse camera) maybe no were planned for your car, and some wiring will be missing from the main harness (like de reverse wire in my car).
If the steering connectors are the same, probably is just plug & play and there is no need for a SW interface, for the reverse camera if you use a non oem model it will need a something like the MetraAX-TOYCAM adapter to add one to the new oem headunit for video and power supply.
like jcboy says: Better look at the back of the unit and compare to the connectors in your car.
That's right Metra adapter will do the job. As far as know if it's a double din radio, any aftermarket option will fit and new adapters should allow you to use the steering wheel controls. Car Stereo Installation 101 is pretty good article that covers the installation of the aftermarket unit, so it should be helpful for you!
MatthewSanders is offline   Reply With Quote
Add USB audio to factory head unit Gladmo2 In Car Entertainment + Electronics (audio / video / alarm) 8 01-02-2013 11:25 PM
Feeler: Pioneer AVH-6850DVD 2-DIN head unit + extras eTiMaGo Items for Sale by private party 19 08-07-2009 09:49 AM
installed head unit... punch In Car Entertainment + Electronics (audio / video / alarm) 16 06-29-2006 12:06 AM
