Old 11-14-2016, 01:06 AM   #1
SirDigby
Drives: 2007 yaris 3 door
Torsen LSD for yaris?
does anyone make a Torsen LSD for the yaris?
anyone have experience with a Torsen LSD on a FWD car?
does it work similar to a 1 way, or is it functioning on decel/braking?
this video was awesome! (but does not give info on decel/braking)
https://www.youtube.com/watch?v=JEiSTzK-A2A
Old 11-14-2016, 01:25 AM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
I haven't heard of a torsion available for the C50, but there is Quaife, KAZZ, OSgiken, and CUSCO(I have)
ArmstrongRacing is offline   Reply With Quote
Old 11-14-2016, 09:28 AM   #3
Ragnar
Drives: Golf 6, Saxo VTS grn, Elise,..
Hello,
I have à Quaife Atb helical diff on my Saxo rally car, it's very efficient.
You don't feel that it's there when you drive but when accelerating in a tight turn you know that it wouldn't be possible to do the same with an open diff.
But I don't think that you need it it on a Yaris with its little Engine. That Will cost you à lot and only be usefull once in a while.
https://www.youtube.com/watch?v=1MvEowuaWoI
Envoyé de mon D5803 en utilisant Tapatalk
Ragnar is offline   Reply With Quote
Old 11-22-2016, 04:57 AM   #4
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Torsen is quite rough for drive shafts !
KimmoKekki is offline   Reply With Quote
Old 11-22-2016, 10:21 AM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Quaife is considered a torsen--since it's not based on friction discs--but uses a different gear mechanism than a traditional torsen.
Quaife:
Torsen:
I installed the Quaife in my gearbox after the supercharger, so I can't say how well it works with the 1.5 NA motor. If you do any offroad driving, or have frequent snow accumulation, it's very helpful for controlling wheel spin on low traction surfaces.
Old 11-22-2016, 10:59 PM   #6
SirDigby
yeah, I thought quaife was built that way. awesome.
and yes, i'm thinking down the road when it's SC.
and yes, I live in Colorado. we sometimes get snow. and mountains can sometimes be steep. :)
Old 11-22-2016, 11:02 PM   #7
CrankyOldMan
I love making 11's in dirt. 😁
Sent from my MotoG3 using Tapatalk
Old 11-23-2016, 10:43 AM   #8
ArmstrongRacing
Data doesn't lie
Very nice explanation Cranky
Old 11-23-2016, 01:35 PM   #9
Ragnar
The Quaife has a bigger torque biaising compared to the Torsen and is lifetime guaranted.
I would not recommend an helical diff to improve the traction on snow or dirt because it multiplies the torque that the wheel with less traction is able to send to the ground and then send it to the wheel with better traction. 0 x 500Nm = 0Nm
The helical diffs are only better on tarmac compared to disc type lsd
Old 11-23-2016, 06:30 PM   #10
SirDigby
Originally Posted by Ragnar View Post
... to improve the traction on snow or dirt because it multiplies the torque that the wheel with less traction is able to send to the ground and then send it to the wheel with better traction.
and why would you not want more power going to the wheel with more traction? that is kinda the point... no, wait. that's the ONLY point...
Old 11-24-2016, 06:03 PM   #11
Ragnar
An helical diff is à tiny bit better comparés to an open diff on snow. The différence between the two is nearly unnoticeable. If you buy à diff to have good traction on snow or mud you need à disc / ramp lsd.
While Racing my rally car I try as much as possible to avoid taking the muddy ropes because I can't accelerate if I have à wheel with nearly no traction.
There is à way to limit this problem : apply à small pressure with your left foot on the brake pedal while accelerating to transfer more torque to the wheel with the most grip.
Old 11-24-2016, 06:14 PM   #12
Ragnar
You are right
Old 11-24-2016, 10:32 PM   #13
SirDigby
ah... the ol' heel toe.
is it funny that I can "hear" your accent in your typing?
(maybe not. I guess it sounds Swedish in my head)
HA!
Old 11-29-2016, 06:17 PM   #14
Dieselking
Drives: 07 1,4d diesel
What type of gearbox do you have?
C50, or C150?
I have a brand new quaife diff here for a C150 type gearbox.
For 6 bolted crownwheels
Dieselking is offline   Reply With Quote
Old 11-29-2016, 10:16 PM   #15
SirDigby
idk. how is identified?
Old 11-30-2016, 12:11 PM   #16
Dieselking
Should be on the wehicle identification plate.
there is a line with color/trim/transmission codes. (might have forgotten some of the codes)
Believe the last one on the line is transmission (tm)
I believe you have a C150
or you can PM me your chassis number, and I can check for you
Old 11-30-2016, 08:56 PM   #17
SirDigby
most likely the c150. isn't the c50 the closed gear ratio 6 speed?
Old 12-03-2016, 12:12 AM   #18
Dieselking
C50 is a stronger version 5 speed gearbox used in bigger engines, 1,6-1,8 liters
C150 is used in 1,0 litre to 1,6 litre engines.
differential, lsd, torsen
Lsd for C51 gearbox thefalls Forced Induction Forum 19 08-16-2012 08:51 AM
Kaaz LSD install / review Blown_xa Performance Modifications 12 03-23-2012 06:18 PM
TRD 2 way clutch LSD kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-05-2009 11:59 AM
TRD Helical LSD kngrsll Items for Sale by private party 18 04-27-2009 11:16 AM
Is LSD Automatic & Manual Same? maxgil05 Performance Modifications 4 04-24-2009 10:57 AM
