Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Central and South America
Old 11-24-2016, 04:19 AM   #1
wnavarro
Drives: 2009 Yaris sedan
Thank you JCBOY.
I from Costa Rica, the climate is tropical, the temperature ranges from 18 to 30 degrees celcius. I think I should use motor oil 20W-50, but I am not sure. What do you think about that?
I think I should change the coolant every year. I donīt know if I shuold use toyota coolant, or if I could use prestone coolant.
Is it necessary or mandatory to clean the injectors every year?
Or just occasionally use the additives, which are put into the gas tank.
Greetings.
wnavarro is offline   Reply With Quote
Old 11-25-2016, 05:40 AM   #2
jcboy
Drives: Sedan 07
Originally Posted by wnavarro View Post
Thank you JCBOY.
Greetings.
Youre welcome.
Yes 20w 50 is perfect, 20w 40 though should be the thinnest you should go. The number with the W is mostly for winter only, which im no expert at, but the manual should say you can go as low as 0w 40.
Coolant? We ver used them, After replacing the original coolant that came with all our cars, i only ever used distilled water. Not surr how hot it gets there in Costa Rica, but we get max of 40degC only, and distilled water work fine. Replacing coolants should be around 5years or x number of kms, not every year.
You dont ever need to clean injectors unless they are acting up or you feel like cleaning them, which isnt necessarily every year. 5 years maybe? Additives you dont need them as much. Just use good quality gasoline like chevron (caltex brand here in Asia) which have injector cleaners.
Sent from my G9208SS using Tapatalk
2009 Yaris sedan problems BennyLava DIY / Maintenance / Service 5 12-26-2020 05:14 PM
Yaris 2 D4D 2009 without AC serpentine belt rasyaya DIY / Maintenance / Service 6 07-17-2014 09:02 AM
2009 Yaris and wind sailing GrayYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 10-26-2013 07:52 PM
Just bought: 2009 Yaris Sedan Prometheus Bound New YARIS Purchase Forum 2 05-11-2013 11:45 PM
