Old 12-05-2016, 10:46 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
In terms of wear, put the tires with the best shoulders to the front. The front tires wear more because they do the steering etc.
Note that it is typically considered safest to have the grippier tires on the rear as it is less likely to cause oversteer. I personally do not agree with this as I would rather be able to brake/steer and deal with a little oversteer, but stats have shown that understeer is safer for most drivers.
Old 12-05-2016, 11:46 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Actually, it is the rear tires that help you stop. That's why the best tires are installed in the rear.
But since we tend to rotate our tires and change all 4 when they are done for, we always put the less worn in front so at the end of the season, all tires are worn equal.
In an ideal world, you would wear down the front tires, and get new tires for the rear and move the old ones to the front.
Sent from my SM-G930W8 using Tapatalk
Old 12-06-2016, 02:41 AM   #3
CoryM
The front tires handle most of the braking due to the weight transfer. 70-80% of braking is done on the front. Best tires on rear is only to reduce oversteer conditions (driving and braking) because inexperienced drivers do not react well to oversteer.
Old 12-06-2016, 11:00 AM   #4
Rigaud
Drives: 2009 Yaris
This......... (y) A fact and based on tire manufacturers and nothing to do with driving experience.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 12-06-2016, 10:36 PM   #5
CoryM
Can you explain the physics of how rear tires would be more important for braking? They do about 20-30% of braking and help provide stability, but the fronts are doing most of the work.
You also may want to look into why virtually every single production vehicle built in the last 30yrs is designed to understeer. Coles notes: Inexperienced/bad drivers do not react well to oversteer and make it worse by doing the wrong thing. Whereas with understeer their natural reaction is the correct one.
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
My car doesn't start yaristhebest General Yaris / Vitz Discussion 11 01-10-2013 10:02 PM
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 10:10 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
