Old 12-15-2016, 12:35 AM   #1
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Three fuel pumps in one year! Highly, highly unlikely. I suspect something else is going on. I know you said you checked the fuses but I'm thinking it is something electrical, perhaps a bad connection, broken wire, or bad ground that has been overlooked. I would start by doing a continuity check on all wiring.
Old 12-15-2016, 04:33 AM   #2
Radosity
Drives: 2008 Toyota Yaris
Okay, I'll put the word to my mechanic. Thank you. It's just over 100k miles, so it's not out of the question it could be some eroding wires.
Radosity is offline   Reply With Quote
2008 yaris, fuel pump
Car cranks but won't start after fuel pump replacement Lightrfire DIY / Maintenance / Service 33 03-10-2016 02:30 AM
Fuel pump assembly locking ring won't thread correctly!! Lightrfire DIY / Maintenance / Service 2 02-26-2016 05:55 PM
Do any Yaris owners use premium gas ? DanMC Third Gen Yaris General Discussion 38 11-06-2013 10:36 AM
Fuel Pump Failure eaglerox DIY / Maintenance / Service 14 03-02-2013 10:27 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
