I agree with the above, there is likely an electrical issue leading to premature failure of the pump.
Fwiw running low on fuel under hard accelleration and braking or cornering or running out of fuel will burn out the pumps in the Yaris, it is not a myth. This is how the pump cools itself
#2 | |
![]() Drives: 2008 Toyota Yaris Join Date: Dec 2016
I saw a detailed post previously about Toyotas, Yaris' at least, being built in such a way that pump burnout isn't possible, but I'm not a gearhead so it could've been bullshit for all I know. Not a bad practice to keep above a half/quarter tank anyways, no reason not to continue topping off. Thanks for all the help yall. :) I'll update again once I get my car back with the results. |
| Tags |
| 2008 yaris, fuel pump |
| Car cranks but won't start after fuel pump replacement | Lightrfire | DIY / Maintenance / Service | 33 | 03-10-2016 02:30 AM |
| Fuel pump assembly locking ring won't thread correctly!! | Lightrfire | DIY / Maintenance / Service | 2 | 02-26-2016 05:55 PM |
| Do any Yaris owners use premium gas ? | DanMC | Third Gen Yaris General Discussion | 38 | 11-06-2013 10:36 AM |
| Fuel Pump Failure | eaglerox | DIY / Maintenance / Service | 14 | 03-02-2013 10:27 AM |
| Hmm my water pump failed again!!!! Could it be the pulley?!?! | YarisSedan | Performance Modifications | 64 | 10-05-2009 09:32 PM |
