Old 12-17-2016, 11:50 AM   #1
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by jra View Post
Engine light flashing usually means your cat is over heating, most likely caused by un-burned fuel in exhaust due to engine missing. could be bad plugs, coils, plug wires, cam or crank sensors, Like Minelio, said see if there are any codes set to point you in the right direction.
no. engine light flashing means "the engine is misfiring right now!"
Old 12-17-2016, 03:40 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
JRA is correct. The CEL will flash when catalyst damage is possible. Typically only seen when the engine is misfiring and dumping raw fuel into the catalyst. I think there are other reasons why it will flash, but they are not common enough for me to remember (or have seen in real life).
Old 12-22-2016, 01:53 AM   #3
Garth g.
Drives: 07 Yaris 2dr hatchback
Thank you for the responses, haven't got around to putting a code reader on the car yet. Since I posted this I've had no problems whatsoever. I plan on using my buddy's scanner this weekend. (240,000k still going!!!) It burns a little bit of oil but who cares!!!!:😈
Garth g. is offline   Reply With Quote
Amber engine warning light Littleloz2016 General Yaris / Vitz Discussion 3 12-16-2016 05:42 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
engine check light Capsat DIY / Maintenance / Service 1 06-24-2012 01:03 PM
