Old 12-19-2016, 08:45 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by Ramon1691 View Post
clean your MAF sensor i was having the same issue even with a new battery and starter i cleaned the sensor and the long cranking stop is worth a shot
The MAF signal has nothing to do with starting the engine. You can unplug it and the engine will still start like normal.
My guess is you might have a leaking injector bleeding fuel. This does two things. One is slightly flood the restart and two, it drops the fuel pressure so the pump has to re pressurize the system.
Blipping the key to start will turn the fuel pump on for a few seconds. Then try starting.
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 12:09 PM
2007 Yaris won't start. Camshaft sensor issue Countryman DIY / Maintenance / Service 14 03-11-2015 06:12 AM
Vitz starting issue Xuhaib DIY / Maintenance / Service 1 10-25-2013 06:13 AM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
2007 Registration and Insurance Vitz-to General Yaris / Vitz Discussion 21 03-28-2006 09:57 PM
