Old 12-27-2016, 09:48 AM   #1
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Toyota mainteinance program reguires brake fluid change every 30K km's !
Just called my local Toyota service !
After 12y your tester shows 1% water on fluid .... yep .. looks to be one more MUST have tester
When brake fluid is old soaked and dirty enough it also ruins piston sealsfrom calipers and mastercylinders !
KTM brakes tilt with less than 6y old fluid !
KimmoKekki is offline   Reply With Quote
Old 12-27-2016, 10:04 AM   #2
bronsin
bronsin's Avatar
But the owners manual doesn't call for It. You forgot to say "in their opinion" Toyota service advises it.
Tester shows LES THAN 1%. I also calibrated the tester by mixing 200 ml fresh fluid with 5 ml water. Tester read 2%.
Finally you can change your own brake fluid for $5.
Dealer gets $99.
Clearly they have incentive to talk you into it.
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
Did you know a different brand of brake fluid will change performance? UberSilver DIY / Maintenance / Service 5 03-05-2013 12:42 PM
Manual Trans fluid change problem dfhnpdx DIY / Maintenance / Service 3 08-12-2012 11:23 PM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 11:53 AM
