Old 12-27-2016, 11:49 AM   #1
tmontague
tmontague's Avatar
Fwiw the plastic cowling that covers the brake fluid reservoir can easily be popped out and removed (just the section above the reservoir) this is by design the make it easy to access.
Old 12-27-2016, 02:41 PM   #2
bronsin
bronsin's Avatar
Have to try it!
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 04:35 AM
Did you know a different brand of brake fluid will change performance? UberSilver DIY / Maintenance / Service 5 03-05-2013 01:42 PM
Manual Trans fluid change problem dfhnpdx DIY / Maintenance / Service 3 08-13-2012 12:23 AM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 12:53 PM
