Old 12-27-2016, 11:06 AM   #1
dogsridewith
Drives: 2007 2-door hatchback
That cowling piece on my 2007 has two tabs that seem to say it would pop off independently of the reported other two pieces of the whole cowl assembly. But that piece seems welded tightly to the piece behind it. Which way does it pry off? Anything else to release but the 2 obvious tabs? Anything else to remove first besides the long rubber molding that removes easily?
Sure would like to get this whole cowl figured out. Thanks.
Old 12-27-2016, 04:56 PM   #2
tmontague
tmontague's Avatar
I just popped those 2 tabs and lifted the small piece of plastic cowling that covers the brake resevoir. You just have to unhook the rubber moulding from the piece
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
Did you know a different brand of brake fluid will change performance? UberSilver DIY / Maintenance / Service 5 03-05-2013 12:42 PM
Manual Trans fluid change problem dfhnpdx DIY / Maintenance / Service 3 08-12-2012 11:23 PM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 11:53 AM
