Old 12-27-2016, 11:27 PM   #1
tmontague
tmontague's Avatar
Originally Posted by dogsridewith View Post
Last two posts sound great. There are several ways to move brake fluid through the system. I do it w/o assistant using a MityVac (suction device, w/ gauge, also used for testing various vacuum diaphragms). Ever encounter or hear trusted account of the Mity Vac pulling in air around wheel cylinder or master cylinder seals...thereby, of course, ruining the bleed job.
I have tried the mighty vac and no matter what it pulls air in through the bleeder for me. That is even with covering it with grease as well as using thread sealant tape.
I just use the 2 person method which is cheap. Quick and woke well.
Down the road I'll likely buy a pressure bleeder but for now the 2 person works fine
Old 12-28-2016, 08:58 AM   #2
bronsin
bronsin's Avatar
I agree mityvac is overkill. Spend your money on something useful!
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
Did you know a different brand of brake fluid will change performance? UberSilver DIY / Maintenance / Service 5 03-05-2013 12:42 PM
Manual Trans fluid change problem dfhnpdx DIY / Maintenance / Service 3 08-12-2012 11:23 PM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 11:53 AM
