The problem I had was that not enough fluid was being drawn down to the bleed nipple to do an adequate flush and bleed. The vacuum was being maintained without issue but I find putting pressure at the main reservoir always flushed way more fluid through the system. I would have a small drop with the mighty vac and a full rush of fluid with the 2 person method.
As long as you have a helper and a block of wood to stop the pedal from going all of the way down it take very little time and gets everything through the brake lines and out.
#2 | |
I've only seen this level of clog--rusty dirt-- happen inside the tip of the nipple, or maybe just inside the wheel cylinder...resolved by removing the nipple completely and clearing nipple/cylinder with a drill bit(s). Stomping the pedal would certainly produce more system pressure to clear rust in the lines, sticky proportioning valves, etc. |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| Will this hold? Plastic bag vs brake fluid | lamadoo | DIY / Maintenance / Service | 7 | 04-25-2013 03:35 AM |
| Did you know a different brand of brake fluid will change performance? | UberSilver | DIY / Maintenance / Service | 5 | 03-05-2013 12:42 PM |
| Manual Trans fluid change problem | dfhnpdx | DIY / Maintenance / Service | 3 | 08-12-2012 11:23 PM |
| Brake lines/brake fluid change out | jstantherprsn | DIY / Maintenance / Service | 3 | 11-02-2010 11:53 AM |
