Old 12-28-2016, 04:59 PM   #1
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Why you should not hit brake pedal to the floor ??
KimmoKekki is offline   Reply With Quote
Old 12-28-2016, 06:05 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Because the master cylinder piston only moves around 1/2 stroke in normal use. The bore wears, which leave a ridge at the end of it's normal stroke. So when you bleed and go all the way to the floor, the rubber piston seal has to go over that ridge and it tears. Then you have to replace the master cylinder.
Never go more than 1/2way to the floor when bleeding (unless master cylinder has just been replaced).
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
Did you know a different brand of brake fluid will change performance? UberSilver DIY / Maintenance / Service 5 03-05-2013 12:42 PM
Manual Trans fluid change problem dfhnpdx DIY / Maintenance / Service 3 08-12-2012 11:23 PM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 11:53 AM
