my rev limiter engages at 6500. the peak HP is at 6000, so it should go beyond that... peak torque is at 4200. so shift light would be best set at ....6150?
#2 | |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
The 3rd Gen manual lists top speed through the gears for the 1NZ-FE manual as 31MPH for 1st, 58 for 2nd, 84 for 3rd and 108 for 4th. These are maximum allowable speeds in each gear, not necessarily the best performance change point. The ECU speed limiter will prevent you reaching the red line in 5th.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| DIY Cruise Control for 2012 Yaris - Good News! | CTScott | Third Gen Yaris General Discussion | 305 | 10-27-2025 01:52 PM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| The most economical speed for the Yaris. | Ilovemyyaris | Fuel Economy Forum | 3 | 03-19-2012 11:33 AM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
