![]() Drives: None yet Join Date: Jan 2017
Yaris Stage Rally
Hello everyone,
I'm ZPERO and I'm new to the forums. I'm a mechanical engineering student and it's about time I buy a car of my own and stop driving other people's cars After looking into many vehicles, I've decided I want a Toyota Yaris! It's inexpensive, it sips gas, and I like the way it looks. I have an interest in getting into stage rally. Or at least RallyX at first. I would love to take a little Yaris with me when I go RalliX-ing, but I have a few questions: In my understanding, the 1NZ-FE engine has a very difficult ECU to reprogram. Cracking it seems to be impossible. Simply replacing it with one that is programmable probably isn't an option, and Rally America rules specific ecu must be the stock unit (can be reprogrammed) or with a piggy back. The 1NZ-FE's ecu also limits the revolutions, I read somewhere that the engine is actually capable of surprisingly high rpm's with upgraded internals and no limiter. Getting rid of this limiter would be preferable for HP gains, as it isn't necessary to use as much pressure to reach the same HP. So, since the ECU is kind of... A difficult obstacle, ̶s̶h̶o̶u̶l̶d̶ ̶I̶ ̶g̶e̶t̶ ̶a̶ ̶2̶0̶1̶6̶ ̶Y̶a̶r̶i̶s̶?̶ ̶T̶h̶e̶ ̶2̶0̶1̶6̶ ̶h̶a̶s̶ ̶a̶ ̶d̶i̶f̶f̶e̶r̶e̶n̶t̶ ̶e̶n̶g̶i̶n̶e̶ ̶a̶s̶ ̶a̶n̶ ̶o̶p̶t̶i̶o̶n̶,̶ ̶t̶h̶e̶ ̶2̶N̶R̶-̶F̶E̶ ̶(̶w̶i̶t̶h̶ ̶d̶u̶a̶l̶ ̶v̶v̶t̶-̶i̶)̶.̶ This engine is not offered in the US, my mistake! Anyone know if that engine has a more "workable" ecu? Anyone know of anyone with a tuned car running some boost, and actually running an ECU tune? (piggyback that actually works, flash, whatever...) Well thanks in advance! Last edited by ZPERO; 01-05-2017 at 05:31 PM. Reason: Addressed mistake. |
#4 | |
Toyota ECUs are always a bugger, and the tuner market is so small for the brand almost none of its vehicles have a hack. Best solution, if you want control and a higher rev limiter, will be a custom "piggy back" setup. An AEM EMS series 2 or 4 will work for your application. Use the OE ECU for the drive by wire and idle, the AEM will do the rest. Does Rally America allow you to play with the trans/diff? I believe you would gain way more speed off-road with a diff and final drive change - and it will cost less than the ECU. Would help to know what class you are building for. A 2ZR swap with an LSD and shorter final drive would be a rocket our there - even with a stock ECU. Ryan Millen is out there being competitive with a completely stock drivetrain in a Rav4, its not all about power. Significantly smaller diameter tires helped his gearing, and a welded diff helps it dig out of turns.
Thanks for your reply!
Yeah, the 2NR-FE is offered in other parts of the globe, but not in the US. I just edited the original post, but I guess you loaded the page before I hit the "Post" button ![]() I believe most Groups (other than the almost stock B-spec) give a lot of freedom when it comes to suspension and transmission, but I just recently read their entire rule book for every single Group category, and i not I have everything mixed up in my head, so I'll check again. Ideally, I would like to start in the almost stock Gropu-B, where the Yaris is one of the 8 cars eligible for the category, and then progress into group 2, which is an "open" class tha allows a lot of modifications, but remains one of the more inexpensive groups, and then group 5, which gives a lot more freedom, and bites a lot more into your wallet. As you can see I'm a little ambitious
2ZR swap. DO IT! Ask how!
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
| Yaris vs Celica | jesh462 | New YARIS Purchase Forum | 11 | 10-18-2012 11:49 PM |
